| So the whole story is I installed a Z1 performance clutch on my 91TT, it was running alright but I had a little chatter so I thought I would try adjusting the clutch pedal to see if that would help. I adjusted it as per Greg D FAQ and it seemed fine till I turned the car on. When I turned it on it got soft and the friction point was very high up, tried bleeding it but it didn't work, seems like air is constantly getting in. Was thinking maybe the slave cyl was the issue but then wouldn't it be soft even when the car is off? My next thought was a problem with the clutch booster, would that make sense? Any help would be appreciated. Thanks
